Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE
Posted by Allan In NE on January 03, 2008 at 08:33:07 from (148.78.243.24):
In Reply to: Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE posted by Charlink on January 03, 2008 at 08:12:21:
The pictures are from my H.
The wedge isn't needed on the M because the angle change isn't needed to point the shaft in the direction of that hole in the radiator. The torque motor just bolts directly to the plate.
Be glad you don't have to orient that wedge on the original plate. That was just an old fashioned bugger to get it "aimed" down and to the right, because it needs to set in there "cocked" at about 5 degrees from "plumb" and holes have to be drilled in the plate to mount the whole she-bang. :>(
Your M "should" just be a "bolt on" deal.
Allan
third party image
