Re: Multiple Remotes on a 706?
Posted by Nat 2 on January 03, 2008 at 11:26:44 from (64.80.108.52):
In Reply to: Multiple Remotes on a 706? posted by georgeky on January 03, 2008 at 09:55:03:
There's only room for two factory remotes under the seat. With all the '06-'66 series tractors in the junkyard these days, it should be simple to find the parts to add the second remote.
Check the existing remote. If it's the older style with a separate cover plate, you can get a "power beyond plate" that will let you add as many additional open-center spool valves as you want. However, most of these tractors had single spools with the integrated end plate.
