Posted by D Slater on January 03, 2008 at 18:05:07 from (72.65.139.197):
In Reply to: MW HYDRAULIC PUMP posted by SD FARMALL on January 03, 2008 at 16:37:18:
Rated at 12 GPM if the inlet or outlets are not restricted and recomended to use a relief valve set at 1000 PSI. Its overkill for the PS and was used to make the tractor hydraulics work anytime engine was running instead of countershaft driven pump. A open center hydraulic valve was used and a priority valve used to run power steering also if desired. They also made a system to power existing valving in the belley pump but it cut flow to 8 GPM. Does your hydraulic reservoir in center housing have a outlet hole in the bottom toward front of tractor? After saying the above I have saw tractors working with the power steering operated by a pump like yours and the power steering was all it powered.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
