Posted by Bob Kerr on January 04, 2008 at 07:28:54 from (64.12.116.73):
In Reply to: f-12 gas regulator posted by 52 G on January 03, 2008 at 19:26:58:
That little "regulator" on the hood is a primer tank used on kero models. If you run out of fuel while using kero it will not start unless you get it cranked within a min or so. The manifold cools off too much to vaporize the oil. You have to use the drain cock on the carb to drain kero out of it and then he brass nut on top comes off and that is where you put a little gas in to get it restarted. There is no pressure relief on the system since the unused fuel goes back to the fuel lines before the pump. Some "may" go back into the main tank at times, but the rest just circulates through the lines until the carb uses it and the main tank replaces it. It basicly gravity feeds the carb. The lines on my 12 are all there and it works great outside of the leaky needle valve in the carb which floods engine if tank is filled full.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
