Re: Starting troubles
Posted by Janicholson on January 04, 2008 at 12:06:56 from (64.83.205.208):
In Reply to: Re: Starting troubles posted by Kristof on January 04, 2008 at 11:28:10:
Sure!
The Ignition System is self contained. there is no connection to the battery or starter, or any other electrical system. The Mag generates its own Voltage, then converts it to spark volts.
The electrical box on the steering post has a mushroom shaped button that is a grounding switch. The switch body is grounded to the box, and a single wire runs from it to the mag side terminal. When the awitch is our, it is open. allowing the mag to produce primary voltage. (tractor runs) When it is in the wire is grounded. this prevents the mag from generating spark.
The wiring diagrams can be found in the archives (use the search for box above, and type in Mob M Diagrams. Good luck, The 22 amps even for a few seconds might have toasted the mag. The points at least. THe manual is necessary for mag servicing, it needs to be kept in time internally. JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
