Tear the engine down to see what the sleeves measure at the bottom that way you will know which sleeves you can use. NOW if you want to realy go and spend money the block can be bored to take the 3 1/4. Chances are your blocks will only take the 3 1/8. In both cases you can mill the head 125 thous. You can get hi-dome sleeve and pistons with rings for less that 300.If you could find a 340 head you get bigger valves. The large pistons and head will give you 40 or so HP. Send e-mail and i can tell you where to get the stuff as i cannot list vendors on this site. I will also give my phone# after getting e-mail. There are more tricks depending on your rules.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
