Re: Some Super C / C questions?
Posted by georgeky on January 04, 2008 at 18:30:31 from (64.12.116.73):
In Reply to: Some Super C / C questions? posted by tractorsam on January 04, 2008 at 16:36:10:
The SC 123 block can go to 3 and 1/4 bore without machine work. I will have to look up th part numbers, but the lower numbered is likely a C-113 and the other C-123. I will post back with info in numbers, if Hugh doesn't come along with then before I find my stuff.
