Re: spun cam bearing
Posted by glennster on January 04, 2008 at 19:31:37 from (68.60.242.156):
In Reply to: spun cam bearing posted by Tom in MN on January 04, 2008 at 18:51:25:
i'd take the block to a competent machine shop, or a machine shop that does hot rod motors.they may be able to resize the bore, bush and pin it, or resize the bore and match up a bearing that will work. see if they can track down the cause of the spun bearing. could be an oiling problem to the front bearing causing the failure.
