Re: Farmall M Radiator paint color
Posted by Goose on January 05, 2008 at 07:05:03 from (199.184.119.22):
In Reply to: Farmall M Radiator paint color posted by Zach Bouchard on January 04, 2008 at 16:51:56:
When we were racing stock cars, radiator rebuilders always said painting a radiator black helped it to dissipate heat, even compared to leaving it unpainted.
I would assume one would prefer the same function on a tractor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
