Re: How to remove Farmall H piston sleeves
Posted by Kristof on January 05, 2008 at 09:41:25 from (81.246.137.31):
In Reply to: How to remove Farmall H piston sleeves posted by Diocona on January 05, 2008 at 09:31:46:
Hey, the sleeves on the H and Super H are dry ones (according to my I&T Shop manual).
Normally they are removed by using a special puller (IH puller SE 1213). But you can easily reproduce one of these. With a couple of round plates and a threaded rod.
You can also try and knock em out from the bottom up with a hammer, but I don't recommend this. Because you can damage the sleeve excessively wich makes it even harder to get it out.
Kind regards
