To get them out you will need a sleeve pulling kit and pull them from bottom up. The bottom of the sleeve puller has a built in flange to catch the sleeve without doing damage to the sleeve. Of course the pistons need to be removed for the puller to be used.
You might want to use some PB Blaster or any other rust type solvent -- kerosene works too to loosen the rust...tap with a wooden block on top of the sleeve after lubcating to get the rust to break loose (it might be good to even soak for a couple days before trying to remove them) Lots of Luck! Go slo and easy!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
