Posted by Bob Havens on January 05, 2008 at 11:28:14 from (75.104.128.59):
In Reply to: H timing HELP posted by Andy Sommer on January 04, 2008 at 22:24:13:
The best way to avoid getting shocked is to have your wife hold the end of the wire while you turn the mag over. If she's bigger than you or you've already tried this method before, cut the adjusting tab off an old spark plug. Connect the spark plug wire and ground the base of the plug and the mag to a common ground. The mag should fire this gap with a hot blue spark when the impulse coupling snaps. Check for spark from the coil (top) terminal.
Assuming the mag works and number one cylinder is at TDC, remove the dist cap and turn the mag until the rotor points to the number one terminal. Install mag to engine in this position. With the kill wire connected and the ignition switch off, turn the engine over slowly and listen for every other snap (1 or 4) of the impulse coupling. This snap should occur at TDC. Rotate the mag on the mount to adjust.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
