Re: 560 diesel fuel pump
Posted by Owen Aaland on January 05, 2008 at 18:58:22 from (65.161.86.40):
In Reply to: 560 diesel fuel pump posted by kerm on January 05, 2008 at 13:33:11:
If you are talking the pivot arm shaft there is a small o-ring on each side of the case under the cap nuts. They can be replaced without removing the pump. If you are talking about the throttle shaft it is more complicated. Those o-rings are on the shaft so some disassembly is required.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
