Posted by ejr-IA on January 05, 2008 at 20:09:46 from (204.11.182.59):
In Reply to: 560 diesel fuel pump posted by kerm on January 05, 2008 at 13:33:11:
Its not that hard.Take the return fuel line off the top cover and the 3 scews that hold it on plus the throtle linkage.Then take the C clip off the shaft going through the top of the pump.Now the shaft can be pulled out each side of the pump in two seperate pieces .Then replace the two O rings and put back together.OH! turn the fuel off too.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
