Re: Hugh MacKay - Creeper Gear Offset Farmalls ???
Posted by Wardner on January 06, 2008 at 19:56:30 from (4.154.241.63):
In Reply to: Hugh MacKay - Creeper Gear Offset Farmalls ??? posted by gots-2-go on January 06, 2008 at 15:03:31:
One of those speed reducers went for $600 at an auction I attended year and a half ago. It is a planetary gear set. The housing didn't look too strong.
If you go to the Farmall Cub site, several people have made the point that the reducer is only meant to slow down the tractor. It can't be used to amplify torque without breaking the left hand final drive. Apparently the upper shaft (pinion shaft) will shear.
It looks like a lousy piece of engineering. When in low range, the differential spider is in constant motion. They don't have the bearings for that kind of abuse.
But what the heck. People who work Cubs are used to repairing them.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
