Posted by James3504 on January 07, 2008 at 16:57:02 from (71.125.101.47):
In Reply to: 450 hyd. posted by Hoss357 on January 07, 2008 at 05:41:42:
Guys I had the same problem. Tried everything I could think of, for months. My experince came from changing the fluid and cleaning the filter. Nothing happened, I tried all the tricks yuns mentioned and nothing worked. Checked all lines and figured out that no oil was coming from the pump. So I decided to push it to the pump. Took the breather cap off the upright tube on top of the resivor. Then used a blow-off chuck with a rubber end and gently put the pressure to the tube with the engine running, pulled on the hydro-touch levers and instantly it bled the system of air. Some times a fellar will try just about anything, but it works. But be careful with the air it don"t take much. when you start to remove the air chuck from the tube be cautious of the escaping pressure. If you would like more specifics give me a shout.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
