Re: 966 main hydraulic pump
Posted by Allan In NE on January 08, 2008 at 05:14:16 from (148.78.243.25):
In Reply to: 966 main hydraulic pump posted by DannyP on January 07, 2008 at 20:09:11:
Boy, I dunno Danny. Ya don't sound like a rookie to me. :>)
Your working on the back "hitch/remote" pump right? Back in the rear end?
Your 70933C1 is the 12 gallon per minute pump. Converts to the 70933 aftermarket number. Should bolt right in there and yes, they all have that little extra "hole" (think the darned thing dead-heads anyway, doesn't it?).
Now, the only thing I would suggest is that if you ever are going to be using this tractor on a loader, a big 12 row planter or the like, that 12 gpm makes for kinda "slow" operation and you might want to consider the bigger 17 gpm pump.
Otherwise, be sure you get the o-ring and gasket seated and it's gonna be just fine.
Allan
