Re: Super A - Hydraulic Fluid Mystery
Posted by Super A on January 08, 2008 at 08:30:39 from (208.1.217.193):
In Reply to: Super A - Hydraulic Fluid Mystery posted by Stones Throw Farm on January 07, 2008 at 10:23:44:
Conventional wisdom here has always been that hydraulic fluid from the Touch Control leaking into the crankcase via the hydraulic pump will lead to bearing failure and other unpleasantness in the engine, due to the fact the lighter hydraulic oil dilutes the engine oil.
IH originally recommended 10wt. oil in the Touch Control unit, later Hy-Tran. Today's replacement, Hy-Tran Ultra, is never recommended by caseIH to be used in an engine crankcase. You won't see any recommendations on a container of 'universal' tractor hydraulic fluid to use it in the crankcase either.
If I were you, I'd get that oil changed, and the hydraulic leak fixed, if you plan to run the tractor.
Al
