Re: W-6 Trade for a late M?
Posted by 26Red on January 08, 2008 at 09:59:42 from (207.109.18.114):
In Reply to: W-6 Trade for a late M? posted by Kirk in ks, on January 08, 2008 at 05:50:42:
I have seen a few loaders and belley mowers on W-6"s. I"m not sure why you"d want a 3pt- yeah they are nice for a grader blade and putting load on 3pt disk. I guess it depends on what you are doing with the tractor. I prefer the pull type implements myself. They seem to be much easier to hook up. Plus that W-6 is easy to get on and off. I"ve slipped a few times getting on my H with muddy boots!
Another pro is that you can add live hydraulics off the front of the engine easily(via the front engine hand crank hole- you don"t have to spend the big bucks on the distributor mounted pump.
