Re: Farmall A front pivot pin
Posted by Hendrik on January 09, 2008 at 02:23:48 from (194.53.253.50):
In Reply to: Re: Farmall A front pivot pin posted by Andrew Z on January 08, 2008 at 19:11:59:
Andrew Z is correct; you need to remove both bolts fully. Even then I had a hard time HAMMERING the pin out. It seemed pretty loose but still took quite some effort to remove and the pin didn't even have wear grooves or nicks...
