Re: Distallate fuel
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Burrhead on February 26, 2000 at 13:03:43 from (12.74.59.78):
In Reply to: Distallate fuel posted by Mike on February 25, 2000 at 10:27:42:
Mike when I read all the threads here I had a thought. If fuel does'nt matter and you just want a nostalgic.
Put regular gas in it, disable the starter and crank it with the hand crank. That usually tends to calm a nostalgia craving.
The reason we used distilate way back when was the price difference. Gasoline was 20-35 cent per gallon and distilate was 8-10 cent.
Like jakee said, it runs through past the piston rings and ruins the oil. Like they all said, it won't run worth a flip on distillate fuel.
If nostalgia is all you want, I think you'll be happier to run gas in the tractor and do your cooking on a wood stove.
If you're planning on parades and get together ordeals, the other folks there don't want to smell these distilate or home brewed fuels burning in their gatherings..
Post A Followup
: Re: Re: Distallate fuel
