1965 ? IH backhoe loader.
Posted by ZANE on January 10, 2008 at 11:35:15 from (205.188.116.73):
I have a 1965 maybe IH backhoe loader tractor. It has the six cylinder engine with shuttle transmission and four speed.
I have a leak at the swing trunion. There is a big seal at the top of the pinion shaft and an O ring at the bottom of the pinion shaft. I recently replaced the seal and the bottom tapered bushings but still have a leak. I think maybe the bushings are worn and letting the O ring come away from the shaft. I can't see how to remove the big pinion shaft from the swing trunion housing so I can repair the bushing/s and the seals. It appears that the big steel busing that contains the upper bronze bushing and the seal on top must be pressed out of the trunion housing before the pinion can be removed.
Anybody know for sure how to fix this or where I might find a repair manual or parts breakdown for reference???
Thanks, Zane
