Re: Changing oil in 350
Posted by Hugh MacKay on January 10, 2008 at 16:29:19 from (64.228.11.25):
In Reply to: Re: Changing oil in 350 posted by Janicholson on January 09, 2008 at 17:41:42:
Jim: Saw accidents are never good, 24 hours later, how is your colleague doing? Wish him a speedy revovery.
I had a close one with a saw just two weeks ago. I was cutting some plywood with my hand held skill saw. I almost rested it on my thigh, when I noticed the blade shield had stuck after my cut, leaving the blade exposed. I'm not sure yet how I moved fast enough, but the blade was still turning when it hit my concrete walk.
There is a much finer line between the accidents and the close calls than most of us realize. All I can say to the masses, don't get too confident if it's never happened to you. Either you've not done much, or your very lucky.
