Re: H M Belly Pumps
Posted by edward_m on January 11, 2008 at 12:06:24 from (67.55.240.130):
In Reply to: H M Belly Pumps posted by Minnesota Marv on January 11, 2008 at 11:07:10:
According to the I&T shop manual, it shows they both use the same unit, so I believe they have the same size reservoir.
You should be able to use the same dip-stick.
