Re: F-30 piston/sleeve pics - Bad news
Posted by Daniel Bear Kelley on January 12, 2008 at 07:23:26 from (206.53.20.159):
In Reply to: F-30 piston/sleeve pics - Bad news posted by Farmboy856 on January 11, 2008 at 17:22:55:
If you can get better ones, GREAT! If you're stuck with these, try Egge Machine (egge.com). They specialize in parts for "obsolete" engines. If they can't help, try talking to a few chrome plating shops or airplane parts places. They can actually build-up the material in the cylinder and then hone it back to factory diameter. They can also put down a layer of hard chrome inside the cylinder. You use soft cast-iron rings with this. Always put a soft metal next to a hard one in situations like this. If you hard-chromed the cylinders, they would last virtually forever. You'd just have to replace the rings on the next rebuild (probably not in your lifetime!). Of course, hard chroming the cylinder walls is Very pricy. But...
