Re: 656 Hydraulic Pump
Posted by TractormanNC on January 12, 2008 at 13:00:43 from (209.42.180.32):
In Reply to: 656 Hydraulic Pump posted by skyharborcowboy on January 12, 2008 at 10:39:06:
Common cause of air in the hyd system is a leaking suction tube O ring between the rear frame and the clutch housing. Simple to check, add 5 gallons of hyd fluid, If cavitation goes away, you have found the problem. Run it 5 gal over full won't hurt a thing, put 1800 hours on one like that.
