Posted by Ted in NE on January 12, 2008 at 15:29:23 from (74.85.105.117):
In Reply to: 656 Hydraulic Pump posted by skyharborcowboy on January 12, 2008 at 10:39:06:
Another cause of air in the hyd system on a 656 is a hole in the return hose from the steering pump oil. This is routed from the top cover down to help super charge the main pump suction tube. Hose can be checked and replaced by removeing the centerlink bracket on the back of the rear frame. Can drain the oil down to inspect or can usually feel the hole in the hose, & replace it. Also while the cover is off take a good look at the bolts that hold the ring gear to the diff.case. These have a habit of breaking off then the bolt comes out and tears of the upper tube the hose goes on, will have a lot of air in the system. I assume you have a clean hyd. filter & good Hy Tran in the rear end, & full to the right level. Ted
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
