Posted by Ted in NE on January 12, 2008 at 19:01:16 from (74.85.105.117):
In Reply to: 656 Hydraulic Pump posted by skyharborcowboy on January 12, 2008 at 10:39:06:
Hyd filter is on the right hand side of the clutch houseing, round cast cover. Lower rear corner. Has 2 bolts holding it on, seals with an Oring. Be carful not to break the corners off when removeing it. Air in system will cause steering wheel to turn free untill it is full of oil. Clean the round screen and install a new filter. The hose could still be the problem but change the filter first.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
