Re: removal of steering wheel
Posted by rumplestiltskin on January 12, 2008 at 22:23:52 from (63.168.30.39):
In Reply to: removal of steering wheel posted by Gary stromquist on January 12, 2008 at 17:57:11:
If the gear puller doesn't work right away, heat up the steering wheel hub just enough to let some candle wax seep between the hub and the shaft. Then try the puller again.
Mark W. in MI
