Re: removal of steering wheel
Posted by RustyFarmall on January 13, 2008 at 06:04:15 from (209.152.78.71):
In Reply to: removal of steering wheel posted by Gary stromquist on January 12, 2008 at 17:57:11:
Look to see if there are some threaded holes on either side of the shaft. If those holes are there, a steering wheel puller is what you need. Just the same as you would use on an older car or truck.
