Re: 6 Volt - 12 Volt A
Posted by Steven f/AZ on January 13, 2008 at 12:01:24 from (24.121.155.84):
In Reply to: 6 Volt - 12 Volt A posted by nyvines on January 13, 2008 at 10:05:10:
If you are going to use it a lot, set up a belt driven alternator from the belt pulley or PTO.
We use our 12v pump on a deep cycle battery and it will run out at least 75 gallons of spray before needing a charge... but it sure is handy to hook up a wire to the four-wheeler and not have to charge batteries at all!
There are also reasonably priced PTO drive spray pumps on the market if you want to completely ditch the 12v pump...
http://www.acepumps.com/en/index.php?/site/products/C12/Roller/
