Basically Cavitation is when the pump doesnt have a liquid to pull on. It is like a the pump is slipping due to the air being pulled and/or created because there is not a Head of fluid in the pump cavity. If you have ever been in a boat and the prop slips and creates air bubbles? That is cavitation as well.
On my tractor I am going to pull the filter out tomorrow and try to replace it because it is more likely then not to be clogged up. I just bought the tractor and it steered fine with just a bit of air in the system. Now I have a lot of air in the system so I think my fluid was probably contaminated and it just settled in the filter cavity allowing things to work relatively good at first but with more use it is now clogging the filter bypass.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
