Re: removal of steering wheel
Posted by bc on January 14, 2008 at 08:48:29 from (70.130.54.235):
In Reply to: removal of steering wheel posted by Gary stromquist on January 12, 2008 at 17:57:11:
I know I used heat to pull mine but I was also replacing the top seal of the hand pump that was leaking anyway. I had the gear puller on tight with a lot of tension. Within seconds of putting the torch up to the outside of the steering wheel hub, it popped free. That was quick enough not to heat the shaft, etc. up. Having the puller under tension while heating helps from applying too much heat but you still have to be careful with rubber parts nearby.
