Re: Removing pulley from 100
Posted by georgeky on January 14, 2008 at 10:53:18 from (205.188.116.73):
In Reply to: Removing pulley from 100 posted by Brian J on January 14, 2008 at 10:42:35:
Check the archives on this forum, several homemade devices for pulling those are here. Or, you need a bearing splitter to put behind the pulley, then attach puller to it. A little heat won't hurt a thing except maybe the seal, which should be replaced anyhow.
When reinstalling heat the pulley in your oven at 400 degrees for about 45 minutes. It will go on then. You have to get it from oven to tractor quickly as it only takes a couple minutes for it to cool and shrink again.
