Re: Broken Stud
Posted by Janicholson on January 14, 2008 at 17:15:59 from (66.173.50.42):
In Reply to: Broken Stud posted by w6tractor on January 14, 2008 at 16:55:14:
Drill through the centers until you feel that bigger will be in the threads. Then use a small tip in an acetylene torch to blow heat through the hole. This over heats the bolt with no effect on the block. Then stick the easy out in and remove them. Several heat cool operations might be needed. JimN
