Re: 80433DD Valve kit
Posted by D Slater on January 14, 2008 at 18:06:12 from (71.182.24.162):
In Reply to: 80433DD Valve kit posted by NewHpuller on January 14, 2008 at 05:54:47:
Use what valves will match IH number 50706 DA intake and 50707 DA exhaust. If you have the old valves double check for the # on them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
