Re: Fixing up an old M for use with a tiller
Posted by 26Red on January 14, 2008 at 21:51:12 from (75.72.129.25):
In Reply to: Fixing up an old M for use with a tiller posted by az tractor guy on January 14, 2008 at 18:36:58:
Whoa! Here's a guy with lots a good questions..
To answer your questions:
Is M a good tiller tractor? Not really unless you already ran a plow or disc through the field.
Can you get a low first gear kit? Yes if you can find one, but it might cost a lot.
Can you add live hydraulics? Yes, but it is not cheap. New pumps run $750 or so. Try Bates Corp dot com for some used ones.
Where can you buy a three point hitch? Try "saginaw county tractor dot com."
Can you swap in a diesel? Sure if you are a good fabricator, and you can find one that fits inbetween the frame rails. Keep in mind the main bearings for the original M Diesel are spendy.
I would advise buying the MTA- you get the live hydraulics, TA, and live pto. Add a 3 point hitch and a tiller and it may do a good enough job. Otherwise, I consider buying a plow, disc and harrow instead of the tiller...and then the M would work just fine.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
