Starter IH # 61061 DA, Delco # 1108913 was used on MD, stage 1 SMD and WD6, SWD6 series until they went to the frame rail chassis. Then on stage 2 and SMTAD and SWD6 after frame rails started being used a change to a positive engagement starter was made on these tractors with electric contact switch located on starter. All these starters and others with 3 bolt mounting will bolt up. Trouble is the MD and stage 1 SM used a clutch housing that even though it looks the same as a stage 2 SM has a different distance from flywheel gear when starter is mounted. On the stage 2 SM the clutch housing is the same between gas and diesel and has the same spacing as T/A tractors so several starters will work if changes to energize them are made.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
