Re: Stage I vs Stage II Super H
Posted by D Slater on January 15, 2008 at 10:10:36 from (72.65.158.73):
In Reply to: Stage I vs Stage II Super H posted by Rich Iowa on January 14, 2008 at 19:09:23:
serial # 19234 and higher changes. Battery box, seat frame, rear light mount and gear shifter. almost all control rods along with some brackets and some electrical wiring. Some drilled holes in top cover eliminated. starter and clutch housing changed. front countershaft retainer and nut. Fuel tank, rear tank support. Also the fuel tank hold down springs were eliminated. Instrument panel changed to mount regulator and on off switch into cover and rear steering support holes changed.
If the tractor was equiped with hydraulics a pump was mounted on engine and reservoir with relief and control valve mounted on clutch housing. Few tractors were sold without hydraulics.
You can't go by battery box location 100 % of the time. IH sold hydraulic seats and battery box packages to install on H and stage 1 SH tractors. 362030 R91 for H and 362031 R91 for SH.
