Re: Front Axle Seperation
Posted by Steven f/AZ on January 15, 2008 at 14:12:03 from (216.67.213.217):
In Reply to: Front Axle Seperation posted by Tims-A on January 15, 2008 at 14:07:34:
Heat and penetrating oil. I use PB Blaster and have had good luck. Others use Deep Creep, Kroil, MarvelMysteryOil, etc.
Another idea that I've used is where the axle is split apart you can drive a wedge in there to open it up.
Also, a pipe or something on the "leg" that goes down to the hub and try twisting it inside the other tube.
