Re: Farmall M Tricycle
Posted by TomH in PA on January 15, 2008 at 16:27:35 from (69.138.20.65):
In Reply to: Re: Farmall M Tricycle posted by Randy-IA on January 15, 2008 at 15:37:45:
Looks like a pretty good size block of wood at the bottom. I'll bet if you multiply out the number of square inches it has on the ground, the PSI under it is not all that much. Just guessing at the numbers:
12x24 inches = 288 sq inches on the ground
12000 lbs of tractor / 288 sq in = 41 PSI
