Posted by funtime on January 16, 2008 at 02:45:55 from (71.204.222.88):
In Reply to: Re: 48 cub mag. posted by El Toro on January 14, 2008 at 05:09:35:
after removing all that grease, i found a crack in the cover that goes over the dist. shaft gear and the rotor. the crack is all the way through the cover. it started at a screw hole. and yes i noted where the timing marks are on the rotor and shaft gear. don't you guys go nowhere. no doubt i'll have more questions for you. you have been a great help. thanks.
