The distributor (with points adjusted to .020" gap on a high lobe of the cam) is installed onto the engine, not connected to the ignition switch, but just loose where its bolts have slots to allow it to rotate for timing. Set the ohm meter to RX1 and ground one of the leads to the distributor case (shiny metal). Touch the other lead to the connection post on the side of the distributor. This puts the points in series between the leads. As the points open, the meter will show infinate resistance. As they close, there will be near zero resistance. Adjust the position of the distributor in its slots so the place where the points just barely break open. That is the static timing position. Tighten it down attach cap and wires, and attach ignition wires. Keep us informed, JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
