Re: IH 666 Brake Specs
Posted by Jerry Gilliam on January 16, 2008 at 07:33:21 from (74.226.70.59):
In Reply to: IH 666 Brake Specs posted by Lance_MF_180 on January 16, 2008 at 07:26:22:
Any TSC, (even here on yesterdays tractors) or dealer will have a Repair manuel for things like repairs and settings, etc. Very helpful and reasonable cost. Around 30 to 35 dollars. Just look for a book that has your model number on it before buying and it will give you all the clutch and brake settings you will need. I always buy one when buying a different model. Jerry
