Re: Weight of Farmall Cub?
Posted by Andrew Z on January 16, 2008 at 10:04:00 from (12.76.132.227):
In Reply to: Weight of Farmall Cub? posted by big red 1 on January 16, 2008 at 09:56:53:
around 1300 - 1500 lbs or so this could be as much as 2000 or more if it has weights, fluid etc..
Andrew
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
