Re: ih 350u hydraulic pump
Posted by agpilot on January 16, 2008 at 13:52:21 from (206.146.78.170):
In Reply to: Re: ih 350u hydraulic pump posted by greg t lang on January 16, 2008 at 08:07:03:
Hello greg t lang: I asked last Spring about replacing a hyd pump on a 350 rowcrop (same pump?)
and Georgeky and JimN indicated the pumps sold here were OK. I guess they are reproduction of the original Cessna pump. I sure could not justify paying CaseIH $1,500 for a factory new pump. I sorta didn't like $500 either so by luck in looking around, I bought a used Farmall 300 parts tractor for $500 plus 30 mile hauling fee rather then $500 for just a pump. Befor I got the pump replaced, I ended up buying another tractor in better all around shape. Of course not many will keep buying tractors but if you want just hyd pressure for a loader on a utility, you could buy an add on pump that attaches to the PTO shaft. That shaft runs all the time if needed. The simple way is buying the pump from this site. I can not answer you directly as to it's quality but I thought I'd comment on my alternate solution. (The best I can say is I've not read negitive comments about the pumps sold here) agpilot
