Re: super m sleeve question
Posted by Roger46 on January 16, 2008 at 19:12:45 from (69.58.143.75):
In Reply to: Re: super m sleeve question posted by glennster on January 16, 2008 at 14:21:29:
I had this problem with a Super C. Apparently, the previous owner had the block decked and my sleeves stuck up too much and the head gasket leaked. I had the sleeves turned down, but if you still can, ideally it would be better to have the block counterbored, because the next person will be cussing you when they do an overhaul. Roger
