Re: Wrapped around the Axle Seperation
Posted by Hugh MacKay on January 17, 2008 at 02:44:27 from (216.208.58.158):
In Reply to: Wrapped around the Axle Seperation posted by Tims-A on January 16, 2008 at 18:33:19:
Tim: I do suggest if you plan to use heat, and I don't see any other solution, you best remove the axle from tractor. The time a friend and I heated a SA center tube red hot from end to end, we though we were going to burn his shop down. We didn't want to stop, thus he called his son to come and set up his Honda pump with fire hose from farm pond. The heat we were creating was drying everything in shop tinder dry. We never did use it on the axle, but we did hose the shop.
If your going to use any type pulling device, do it only after the center tube of that little axle is red hot. Some of these guys Allan included aren't stopping to think that could be stuck just as solid as any big tractor. I have done the axles on big tractors as well, and yes you can do what Allan is showing in his photo. You hook two big tractors, or any other device to that little axle, if stuck solid enough you may snap the spindle tubes and spindles of the axle. Look up the cost of a center tube, far less expensive than the end parts and spindles.
