Re: Super A Hydraulics - Still working on it
Posted by Janicholson on January 17, 2008 at 06:08:33 from (199.17.6.122):
In Reply to: Super A Hydraulics - Still working on it posted by Stones Throw Farm on January 17, 2008 at 05:45:58:
I it were me, I would take the steel lines off and drill a 1/4 inch hole in the top side of each one. I would then weld a 1/8" pipe coupling cut in half to each hole so I could plug them up. This would allow me to pump the line full of oil with no uncertainty. It would also allow bleeding of the pressure line, and testing of pressures. Another possible solution is to put the remote access block between the resivoir unit and the lines. This would also give access to the fluids. JimN
