Re: H shift lever squeaks
Posted by Theman on January 17, 2008 at 13:50:19 from (65.248.77.5):
In Reply to: H shift lever squeaks posted by JFavor on January 16, 2008 at 16:56:53:
1, The tower is on the opposite side of oil coming off of the ring gear plus the shift rails are directly below it blocking any splashes. Unfortunately, the shifter area is the 'breather' of the transmission case. All moisture is pulled in right here and it is where the worst corrosion and wear occurs. The pins were so worn on my '51 H the shifter could wobble around the outside of the rail slots.
2, Pilot Knob Restorations has the caps if you can't find anything locally.
